bogging when cold? and other issue?
    in my 92 exr i have an h22a with a jdm p13 ecu and f22 fuel injectors, i used the external coil distributor , f22 harness, the car runs good when hot but is fairly hard pon fuel and when i first start it in the morning cold, it bogs and i have to feather the gas till it warms up then it works great, also when i hit vtec and pass 6500 the tach will act funny and it almost sounds like my ecu clicks? any suggestions?
    Just asking Why do you have, f22 fuel injectors in a h22 that might be one of your problem. when bogging when cold.
    92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
    91 cb9 wagon
      well i have the h22 injectors just they were in a box with some d15 injectors and i cant tell them apart. so i just used the f22 ones,
        Most of the h22 injectors are green at the bottom
        91 cb9 wagon
          i found the injectors for it, installed them and the car works great.( thanks for the hint on the green tip for the injectors,) but i'm still having the issue with the tach acting funny, not quite sure what that could be?
          and i also have no vtec untill the engine is at running temp?
            Is the RPM tach jumping around when running?
            91 cb9 wagon
