engine stumbles/vibrates...?
    it happens in gear 1 through 3. mostly just 1st and 2nd gears.
    its like what happens when you let go of the clutch to early. then when im in 2nd gear and get close to redline it stumbles to get there.
    could it be the engine mounts?
    Originally posted by mister_cb7
    bump.
    Man o man, don't bump your own thread, ESPECIALLY only 3 hours later. Good way to get the mods pissed off at you.
    In regards to your issue, sounds like spark or fuel issues. maybe a tune up, and change your fuel filter.
      Also might be a symptom of bad EGR valve or blocked EGR ports, when was the last time either was cleaned? There is a Service Bulletin out on it, I believe 98-075, not a hard diy.
        Update. one of my spark plugs was dead. changed it and now its running good again.
          yeaaaaa,
          now its my turn to get my car better
