i understand doing a comp test will tell you if you have low or high comp in the cylinders. but how does doing a comp test tell you if its rings or valve issues? i just had an engine swapped (do to blown rod) from a f22a6 to f22a1 but had them put in my a6 cam into the swapped engine (to keep it an a6). ive been noticing that the motor is needing oil every other day or so. head and valve cover gasket is new. i have no oil in the spark plug tubes so im assuming the seals and o-rings are in good shape. but sometimes when i put a lot of load to the engine it puffs a cloud of blue smoke.....any thoughts?
compression test
yea. i plan on pulling the ignition and fuel pump fuses. or would pulling the ecu fuse work?Originally posted by thepowderblue View PostYou do know when you do the test you have to unplug your injectors right?Last edited by jewelproject; 08-02-2011, 04:22 PM.
RIP 4/23/12
...lets not forget, the 88" Z31 turbo, are my dailys
I'm thinking the same thought. The engine I had swapped did have 130k on it... But I could be wrong. I just topped off the oil and no smoke?? I even redlined it. WTF??Originally posted by chorne1787 View Postsounds like tired rings i had a del sol that did this same thing anywhere over 3k rpm
RIP 4/23/12
Omg. You do know where your injectors are right? Unplug the wires going in to them.Originally posted by jewelproject View PostLocation of that plug??? I tried following the wire harness to find it's source but it goes under im and then I lose it where it leads to.
