diy cross drilled rotors?
    Anybody ever do diy cross drilled rotors? I have always wondered why people buy $300 rotors when you can simply cross drill them yourself with a drill press. I did some research on it and read this
    Originally Posted by BSQ5 on Jan/13/03
    Quote: Weston on Jan/12/03Has anyone here drilled rotors themself?
    Weston,
    I have actually cross-drilled my own rotors on 2 seperate cars. The first car that I cross-drilled the rotors on was my '86 Honda CRX Si. I had a problem with the CRX Si warping the front rotors (yes...I used a torque wrench to tighten the lug nuts). I initially had the rotors turned, but they eventually warped again. So, then I decided to purchase a new set of front rotors and cross-drilling them to see if it would prevent warping. After I cross-drilled the rotors I never had a problem with warping. Those particular rotors were cross-drilled for approx. 6 years.
    When I purchased my '94 GS-R I had concerns that the rotors might eventually warp (similiar to the CRX Si). So after owning the car for almost 1 year, I decided to cross-drill the front and rear rotors. Since that time, I have done 7 HPDE (hi-performance driver education) classes (~21 hours of track time) and they rotors have performed flawlessly. My brother-in-law used to own a GS-R with identical suspension, brake pads and street tires, but the only difference was my brake rotors were cross-drilled and we ran similiar lap time (within .5 second of each other). After each lapping session we measured our rotor temperatures with a laser pyrometer and my brake rotors were usually 100-150 degrees less. So, I'm a firm believer in cross-drilled rotors. BTW, I have had my Integra rotors cross-drilled for 8 years now and I haven't had a single problem.
    For my CRX Si cross-drilled brake rotors I used a "swept" pattern (see picture below). With this pattern there is a left and right side pattern.
    For my GS-R, I used a more univeral swept pattern (see picture below). This allowed the same pattern to be used on either rotor. The pattern that I used was not a tightly spaces (ie. the holes were spaced out more).
    I layed out the pattern on a large thick piece of paper, using a compose. After the pattern was made, I transfered it onto the rotor. I drilled the holes using a drill press and a 1/4" titanium drill bit. I also chamfered the holes using a countersinking bit.
    Well, there is my $.02 on the matter. HTH.
    It seems like this will give a great look to a car and have a function at the same time. Next time I do rotors, I will be trying this out to see how it works for me.
    I bought the Brembos on my car right now from a company that took Brembo blanks and drilled/slotted them themselves. I assume this is no different than doing it yourself, as long as you have the proper tools.
    I don't know that I'd follow advice from someone that uses a "compose".
    Honestly though, it's unproven that drilled rotors really help, and they CAN crack. When I replace the rotors on my car, I'm just putting regular Brembo blanks on it.
      In reality all of those little holes are a loss of surface area.
      You are not driving an accord hard enough most of the time to get the rotors hot enough to really need additional cooling.
        Go with slotted rotors if you are going to do anything. I run those on my accord, vette, and my vr4 and no problems. I had drilled and slotted rotors on my stealth r/t and had a ton of stress cracks around the drilled areas. I saw that, swapped them for another set of drilled rotors, and the same thing happend again a few months later. Been using slotted rotors on my cars and never any problems.
          both slotted and drilled rotors will shave pad material off faster. that means you will burn through pads faster than with regular rotors. good for performance. bad for a car that you dont want to have to service more often than necessary. especially since cb7 rotors should be machined when pads are installed, and we all know what a bitch they are to get off.
            It also has a lot to do with convenience, most people are not trying to go thru all that when they can just buy it. Plus nobody really has access to a drill press or is trying to get access to a drill press. It might be easy to do and easy access for u but for the majority its just a hassle.
