location of the check engine light plug for jumper wire
    where is the exact location of where i need to plug it into.i know its passenger side near glove box but do i need to take apart glove box to get to it or remove side panel.need help.thanks
    Look under the dash right above the kick panel. You may need to pop off the kick panel to find it. Its a blue plug taped to the underdash harness with blue tape.
    1992 Accord Wagon (RETIRED)
      does the check engine light have to be on when i check the codes or is it saved in there.because my light only comes on at normal operating temperature, idle for about 5 or 10 min.
        http://www.cb7tuner.com/vbb/showthread.php?t=21259
        There is the sticky for diagnosing a check engine light. It'll tell you everything you need to know.
        Always make sure to read the sticky's they have vital information in them. plus using the search function found in the "control" section will take you a long way! there are tons of threads about everything you can imagine so chances are your question has already been asked and answered, and that is why this is such an awesome site! welcome aboard!!!!!
        Originally posted by wed3k
        are you serious? thats like blaming the rubber because you didn't get the right size for your dick.
