NGK o2 sensor help
    NGK o2 sensor help
    Sup guys, I'm trying to order an NGK o2 sensor for my 93 SE on ebay, but I see that there are two different ones (part number-wise). There's the "NGK/NTK 24169 SENSOR" and the "NGK/NTK 24042 SENSOR"....anyone know the difference?
    bump for help
      Get the one made for your particular model. The EX/SE has a different plug and wire length than the LX/DX.
        If you order the wrong one...you can always just splice in more wire in order to reach the plug.
          Splicing can alter the resistance, which could render the new sensor useless. If you DO choose to splice, splice the wires on the sensor. DO NOT cut the wires on your car.
            Sorry I kind of put that in an unclear, vague way. I didn't mean splice the wires on the harness. I meant the o2 sensor itself like you said above.
              I just wanted to clarify. YOU may know better... but others reading this may not! I've known people to hack their wiring harnesses to hell... and that's no fun to replace!
              My own headlight harness was hacked up by a friend of mine (who I trusted... before I knew any better.)
                The Ebay listings for the NGK o2 sensors are so vague, it's hard to determine which is the correct one I need
                  Go to rockauto.com and get their Denso sensor. It's about $40.
                  I wouldn't feel comfortable buying a sensor from an ebay seller, especially since there are different ones for our cars... if you get the wrong one, it may not work properly.
                    Great, found it! Thanks a lot Deev!
