Odometer Stops Working..Sometimes
    My odometer/trip odometer has been quitting on me intermittently lately. All the gauges are reading fine(speedo,tach,fuel,temp) with NO dropping or bouncing so it makes me think it's not the vss. There isn't a certain mileage that it stops at, it's completely random, as it is when it starts working again. I recently changed the bulbs in the cluster and it started about a week after. I've pulled the dash back apart to double check that the harnesses are all plugged in tight, and they are. The cluster has 270xxx miles if that matters. Ideas?
    short
    hmm
    I'm not going to be much help, but that's odd that it would malfunction on it's own.... In mine, the speedo and Odometer stop working simultaneously. Effin blows. Gotta go a piece from the junkyard to hopefully fix both of these issues.
    Good luck on yours, let us know when you figure it out.
      Pull the cluster back apart and make sure the odometer plug isn't loose in the board.
        my car does the same thing and my check engine light comes on .. if i punch the gas it comes back for a while.. weird... its caused by the speed sensor i can see mine is cracked .. im pullin my trans off soon anyways for a lsd tran and a new clutch
