oil leak
    oil leak
    hey everyone 93 f22a6 im not sure if my oil pressure sensor is leaking. i degreased my engine when i noticed that one of the transmission rubber lines was spraying my engine so i put real clamps on the two and that solved that leak now its kinda wet were the sensor is. is there a seal behind the distributer that could be leaking? ever since i degreased my engine all is clean and dry except under the distributer. thanks for the help.
    (sold to h22wagon93, granite cb7 $1000.00) and c91bse7 cash with trade, jdmfreak, thanks guys!
    There's a rubber o ring that goes on the distributor that is usually the cause of that.
      sounds like a cheap part, ill look on my popular parts source Ebay. thanks bro its worth a shot
      is it as easy as taking the distributer off and replace that seal or is there alot involved. i just looked at the seal on ebay and it looked a little thick. i expected to see a thin oring, but its only $8.73 shipped
        It's pretty much as simple as tou just said....... and go get it from honda. It's like a 2 or 3 dollar part......
          oops looks like he edited it so never got to see it.
          so remove distributer bolts, remove the distributer and there it is.
            Yes
              it doesnt mess up the timing?
              Originally posted by scudweiser
              i farted while i was getting head once, i was drunk.
                im assuming to take it out carefully and not let the shaft spin. im planing on taking off the cap first so i can see what position the rotor is and then work the distributer off slowly
                  There's also an internal seal on the distributor. After you change out the one around the shaft, if you notice there's still a leak, search for the other one. There's a DIY on it here.
                  Or do them both at once since they are cheap and you have to remove the dist for each procedure. Might as well remove it only once.
                  You partially disassemble the distributor but it's not hard and doing both will solve the leak.
                  90 Accord Ex, F22A4. Slight fire damage.
                    cool thanks for the info, i did order a distributer seal but now your telling me there is 2 so i dont even know which 1 is coming.
