Oil change
    Oil change
    I think I might have a blown head gasket.
    I put coolant into my car a while ago and the next day when I drove it, it overheated like crazy and shut off a few times, then i noticed all the coolant was gone and the radiator was empty.
    I kept driving it and only used water and no coolant and the water doesn't seem to disappear. Did I use the wrong coolant or was that a one time thing somehow? I don't know. Given the situation, would an oil change be smart right now?
    u could change your oil and see if any coolant is in it it should be like a orange color if there is coolant in your oil i think..
    http://www.cb7tuner.com/vbb/showthre...85#post2984985
      Sounds to me like you didn't put enough coolant in. Did you let the car run after you filled the radiator and then refill it?
        You dont need to change your oil unless its past due. Pull out your dipstick and see if its milky. Also you cant figure its a head gasket just because of that it could be a number of things.
        1. Change your thermostat.
        2. Check for any coolant leaks.
        3. Bleed your cooling system.
        Just to name a few.
        1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
        Originally posted by keepinitclean
        I give it 2 weeks before you sell it.
