My F22A has 250,000 miles and the valves started ticking. I did a valve adjustment and it seems to run slightly better now, but still ticking. Are they just worn because it has so many miles now or should I check them again?
Valve ticking
>it happen to me before but after overhauling my cylinder head including the rocker assembly the ticking went away.Originally posted by Flyingsheep View PostMy F22A has 250,000 miles and the valves started ticking. I did a valve adjustment and it seems to run slightly better now, but still ticking. Are they just worn because it has so many miles now or should I check them again?
Yup, you can check the valve again when the motor is cold but make sure that your motor oil is clean my f22 use to make that sound when the oil was Dirty.Originally posted by Flyingsheep View PostMy F22A has 250,000 miles and the valves started ticking. I did a valve adjustment and it seems to run slightly better now, but still ticking. Are they just worn because it has so many miles now or should I check them again?
that can affect compression and map sensor readings.Originally posted by Darkcloud View PostGo .006 and .008, I did those specs no issues no ticking at all either
