My 91 Accord ex got flooded out the other day got everything dried out including ecu.I started it up and and there is a grinding sounds like its coming from behind the timing cover by the cam gear.I pulled the belt (a/c and p/s) off just to make sure it wasnt on the outside. Could this be belt tensioner or water pump? It was not grinding before. I am a noob and not a mechanic but mechanically inclined and have basic knowledge under the hood.
Grinding coming from behind timing cover
Last edited by Bucky 91accord; 08-25-2011, 07:08 PM. Reason: added info about my knowledge and which belts i took offTags: None
Id be willing to bet either rust has formed, or you got dirt due to the flood. Time to pop open the timing cover and see whats up.Originally posted by Bucky 91accord View PostOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I took it to my friends shop and had him do it. So I'm pretty sure he took care of the timing. So what is a dizzy? Is that the cam gear? I was gonna have him take off the balance shaft belt but he said it is all thats driving the oil pump??? Is that true or is there another way to drive the oil pump after the belt is removed? Thanks for lookin out on the timing adjustment dj
A dizzy is the distributor, where your plug wires plug into. And to my knowledge the balance shaft belt does not drive the oil pump. Many members have theirs removed, myself included, and our cars havent blown up. Id say hes full of shit. Removing the belt just reduces the rotating mass of the engine, and its not a whole lot. So if your not modding your car for speed, I'd leave it alone.Originally posted by Bucky 91accord View PostI took it to my friends shop and had him do it. So I'm pretty sure he took care of the timing. So what is a dizzy? I was gonna have him take off the balance shaft belt but he said it is all thats driving the oil pump??? Is that true or is there another way to drive the oil pump after the belt is removed? Thanks for lookin out on the timing adjustment dj
That's what I didn't understand did a lot of reading on CB7tuner before and after I joined trying to learn as much as possible and I know that balance shaft elimination is a common term. I just wasn't sure if there was differnt versions of the F22A4. I had a chevy silverado that was built in mexico and reqiured different parts ie. Water pump wasn't the standard partOriginally posted by dj_ender View PostA dizzy is the distributor, where your plug wires plug into. And to my knowledge the balance shaft belt does not drive the oil pump. Many members have theirs removed, myself included, and our cars havent blown up. Id say hes full of shit. Removing the belt just reduces the rotating mass of the engine, and its not a whole lot. So if your not modding your car for speed, I'd leave it alone.
The a1 and the a4 are identical other than the tubular exhaust manifold that comes on the a4. The a6 is identical except it has a hotter cam, a larger intake manifold with secondary runners, and a different ecu.Originally posted by Bucky 91accord View PostThat's what I didn't understand did a lot of reading on CB7tuner before and after I joined trying to learn as much as possible and I know that balance shaft elimination is a common term. I just wasn't sure if there was differnt versions of the F22A4. I had a chevy silverado that was built in mexico and reqiured different parts ie. Water pump wasn't the standard partOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
