o2 sensor code 1
    o2 sensor code 1
    Hey CB7 friends,
    I need help with my o2 sensor code 1, I did the swap almost about 6 months ago but the code 1 keeps coming up, I replace the sensor twice. Can any tell me what can be the cause? it is driving me crazy
    Thank you.
    You did what swap?
      We swap a h22a4 with obd1 wiring on a 92 accord.
        1) What brand sensors have you used? Bosch sensors do not work properly.
        2) What OBD1 wiring are you referring to? Did you use an OBD1 Prelude harness, or just add wires to the Accord harness?
        3) What ECU are you using?
          I used a NKG and now a Delco, reset the ecu and nothing. We just adjust the wiring to fit the car. We use the same wiring from the Accord. This was a OBD2 and modify to fit OBD1.
