Hi guys,
I am unemployed so price is very important. But keeping my car in good shape so I can go out and find a job is also very important. Thus I have posted this thread for pointers and suggestions.
My car: 1990 Accord LX 4AT.
The engine mounts are all cracked. I know for sure that the front torque and the 2 sides are cracked. The rear one I cannot see at all but what is the best way to look at it? Here's the problem, my car barely shake in D4. Shakes a little more in neutral, shakes a lot in reverse. But none of these conditions are unbearable.
I would like to fix at least the front and 2 sides before it become worse and the engine starts making noise on take off or move too much. Given the condition of my car shakes mostly when in reverse, do you guys think that the rear mount can still hold up for a while, given that it shakes only in reverse? By changing out the other 3 mounts, it should take some stress off the rear one right? I don't want to mess with the rear mount b/c I have to take the intake manifold off and thus spend more on the gaskets and all.
For the rear mount, most place sells these without the bracket, I could reuse my old one right? Also some mounts are sold without the solenoid, could I reuse my old solenoid? Or should I buy one with the solenoid included?
***Do I have to remove the radiator to get the torque mount out? I top bolt should be no problem but the bottom one is going to be a problem as it's lower with much less space to work with.***
I found this website that sells only engine mounts and mostly Anchor brand for cheap with free shipping with $50 or more purchase. Any one experience with them?
http://www.enginemountwarehouse.com/
Thanks for any suggestions and help.
