Ecu plate removal
    Ecu plate removal
    I've been trying to remove the metal plate that holds the ecu and tcu from the floorboard but there is no clearance. Is there a certain way you are supposed to remove it...I don't wanna force anything because I'm worried about possibly damaging the wires, etc. I've tried to search around the site....maybe it's something simple I am missing?
    Have you unbolted it yet if thats what you mean by clearance? But if so it usal helps to unplug the TCU fist then the ecu.
    STANCE|WORKS
      Yeah, i've unbolted it so far but as for unplugging the tcu it's the kind where you pinch the tabs in then pull?
        I used a flat head to push in the tabs (I have fat fingers lol) but they just pulled right out. Then I folded over the whole board and unbolted everything from it giving you more working room to remove the ecu. hope it helps IDK...
        STANCE|WORKS
          No luck so far, the tabs are on the top of the wire harness right?
            Just stick your fingers in there around the plug and feel where the tabs are at (I'm not sure if they are on the top or bottom, I just know they are near the center of the harness). Then do like dude said, use one hand and press the tab with something (a small flathead or whatever) and with the other hand pull the harness out. Its a bunch of bullshit, I've been thru it a couple of times but you'll be alright.
              Pull your carpet back more.
              Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
              93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
                Yes it's definitely bullshit lol. I got so pissed I used a pair of vice grips to pull one out but I'm still working on the other. I had no idea this was gonna be so aggravating
                  It normally takes me 15 minutes
                    It takes me 5 mins now because I just left the cover off. But when you go to a p12 it doesn't fit in the cover anyways lol.
                    STANCE|WORKS
                      You got all the nuts off? Then yank the effin thing off!
                      Freedom Is Not Free
                      U.S Army 02/08 Medically Discharged
                        I finally got everything off! After the tcu wire harnesses were out, the ecu ones came out like butter lol(without the use of the vice grips but with the flathead screwdriver). but damn that was a test of my nerves haha
                        Thanks goes out to everybody that helped me out on this post!!!!! I'd probably still be cursing and sweating away if it wasn't for any of you guys
                          No problem dude just glad we could help.
                          STANCE|WORKS
