i have a 91 acoord and this one day i was drivin and out of no were i lost all clutch pressure so i went home and i changed the slave and the master cylinders bled it and nothing so then i droped the tranny and changed the clutch and im still having the same probled wat do you guys think it it any help apreciated
no cluctch pressure
Wow I'm glad I saw this. I'm having the same problem after replacing the clutch master cylinder with a rebuilt one. First it was leaking and I was freaking out, then I figured out the drain plug on the MC wasn't tightened (thanks autozone) so I tightened it and now it only builds half pressure.
I was thinking it's because I need to adjust the rod that connects to the pedal? Because it travels halfway freely and then you feel pressure and it partially disengages the clutch. I bled it for a long time.
Fastest way to bleed the system quick is with a small line of vacuum line on the bleeder nipple, and a cup of water, this way, you can tell if the lines are properly bleeded or not...
here see this....
