engine issue
    engine issue
    so lately my oil pan bolt strip and I got the whole pan and bolt replace .... but and the last two days when ever I hold the clutch and idling at a redlight or stop sign etc my car engine jumps not sure why .... pls help
    91 lx that I call Cinnamon
    "stripped", "replaced"... sorry... grammar nazi. The past tense exists for a reason.
    Anyway, your oil pan has nothing to do with your engine "jumping", if what you mean by "jumping" is that your engine is physically moving. If the engine moves more than it should, it means your motor mounts are broken. Replace them.
    If the "jumping" you are referring to is your idle, as in your tachometer is rapidly moving up and down, then you need to read the thread at the top of this section that says "read here first" (catchy title, no? it's there for a reason... common problems are addressed there!) You will find a link to a thread by HondaFan81 that tells you how to properly set your base idle.
