balance shaft belt delete
    What drives the oil pump on a F22A4 after balance shaft elimination or belt removal .
    I know that balance shaft elimination is possible and I know Bisi and others sell kits. I also know the belt can be removed leaving the shafts in place. I'm not looking for antithetical information other than What drives the oil pump because it is driven by the balance shaft belt. Do you reroute the timing belt? Thanks ahead of time
    The oil pump is not driven by a belt. The crankshaft drives it with a gear.
    PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
    Listen or download the first 4 songs I completed for my new upcoming album here!!
    My member's ride
      Since the topic has been opened, So what is the purpose of this belt besides reducing vibration?
        Does anyone have pics of this? Cause in the Haynes it looked like its driven by the BS belt, and when my mechanic was just replacing timing belt tensioner he said he couldn't remove the BS belt cause it drove the oil pump. Just so you know I'm not questioning you I just wanted something to show him the next time I had him work on my car.
          BS belt?
            My understanding of it is because a inline 4 cylinder motor is not symmetrical it creates vibration and the balance shafts counter act that vibration. BS belt = balance shaft belt. Still new to this forum thing haven't quite figured out how to quote other posts from different threads yet
            Last edited by Bucky 91accord; 09-12-2011, 08:57 PM. Reason: admission of my being a noob to forums
              The balance shaft belt does not drive the oil pump. I've been driving without a balance shaft belt for years. i just removed the belt. Left the shafts in.
              My Members Ride Thread
                and you didnt do no kind of delete kit?
                  So I can get to the balance shaft belt without removing the lower timing cover?
                    I removed the "BS belt" lol. Hood vibrates at idle, not really noticeable.
                    1992 Accord Wagon (RETIRED)
                      I would think you would still have to remove that lower timing cover.
                        Yes and no......
                        Your supposed to but I cheated.
                          a "delete kit" is not necessary to remove the balance shaft belt. You can just remove the belt. Delete kits are to remove the actual balance shafts themselves. Yes you have to remove the timing belt cover to remove the balance shaft belt.
                            Oh ok I thought you had to install the delete kit to do it properly. But that is just to make it clean looking, correct?
                              So just so I understand right. The pulley on the rear of the motor above the crank pulley is the balance shaft and that goes through the oil pump. And that's not the drive pulley for the oil pump
