Im sure many of you have had this problem, but I cant figure it out. I have a 91 Accord, 5 speed that is all stock except for a couple minor things. The problem I am having is when it sits at idle the RPMs rev up then come down and its constant. And with it being a standar you can only imagine how often it does it, at stops signs and red lights, its really annoying. If you can help me out and let me know what it is and how to fix it I would GREATLY appriciate it.
91 Accord Idle problem.
check for oil in your spark plugs. also check for any loose vac. hoses.Originally posted by desertratt View PostIm sure many of you have had this problem, but I cant figure it out. I have a 91 Accord, 5 speed that is all stock except for a couple minor things. The problem I am having is when it sits at idle the RPMs rev up then come down and its constant. And with it being a standar you can only imagine how often it does it, at stops signs and red lights, its really annoying. If you can help me out and let me know what it is and how to fix it I would GREATLY appriciate it.
its hunting its common it happen to me and it fix it self
http://www.youtube.com/watch?v=-gK2UUAevMY
91 lx that I call Cinnamon
Check for resistance across the IACV before replacing it.Originally posted by 559cb7559 View Posti had the same problem with my cb7 i try cleaning my iacv but no luck i ended up replacing it
I don't have the manual near me but you should be reading between 8-15 ohms, If I recall correctly.
