Idle issue....
    Idle issue....
    on occasion my bone stock 1991 f22a4 will start up and idle kinda rough for up to 10 seconds max.... I have reset the ECU and cleaned the spark plugs and cleaned in side the cap....the spark plugs are NGK and the wires are blue NGK and the cap is O.E.M. runs and drives great after the problem....any ideas? I am annoyed at this point....but the car runs great and flew through D.E.Q with no problems....maybe the fuel filter?....HELP
    clean your IACV
    TKCB792
      Originally posted by TKCB790 View Post
      clean your IACV
      http://www.cb7tuner.com/vbb/showthre...lean+FITV+IACV
      heres the link to help
      TKCB792
        if Your IACV doesn't help clean your FITV (Fast Idle Thermo Valve) it's attached to the throttle body. take off the little backing plate and drench it all in carb cleaner. then make sure the little (quarter sized) white (probably yellowish now) silicone plate is screwed nice and snug.
          That was FAST!!! I will clean it first thing tomorrow....
            already keep us posted
            TKCB792
              did all the above and it still the same....
                Do you have any CEL's?
                  nope....no CEL....still driving it the way it is and it is more of an annoyance for the first 10 seconds gthen it drives great.....I dont get it!!!!HELP!!!
                    Go check your plug wires, make sure they are securely attached to the plugs. How old are the wires? I had a very similar issue and it was due to a bad coil wire. It was actually arcing on the coil contact, changed it and it went away. Also sounds like your timing may be off.
