I was rotating my tires tonight and I noticed the my driver side tire was the only one that was worn out on the outside, it is lowered but all the other tires were still in good condition. Also it was backed into 2 years ago, so is there anyway to fix it myself or would it be better to take it to an alignment shop. Any help would be appreciated.
rear wheel alignment
i would suggest getting an alinment, it may just need an adjustment.
worn out tie rods and suspension bushing will cause miss alingment and will need to be corrected first.Budget Street is offline working in the shop
drop the mouse and pick up a wrench
Originally posted by deevergoteGood for you. You don't even know how to spell VTEC.
I believe the issue is -=REAR=- alignment.Originally posted by budget street View Postworn out tie rods
regardless:
def get it checked out, never know when its your frame.
an alignment shop should be able to either:
a. fix it
or
b. tell you the frame or something else is out of place/bent.
