black box?
    black box?
    okay i think the part im talking about is called a black box its located by the battery on the right feder i was just wondering if i need it for my car to be running good or if not having it is okay
    THEN NOW
    What car are you talking about?
      that "black box" is actually a vacuum resevoir for a diafram in the intake. if you have a aftermarket intake you can eliminate that "black box" follow the vacuum line all the way to the intake and cap it off so you dont have a vacuum leak. if you have a stock intake i would leave it alone
      Budget Street is offline working in the shop
      drop the mouse and pick up a wrench
      Good for you. You don't even know how to spell VTEC.
        ok sorry for the lack of info its a 1990 accord ex sedan auto but since i dont
        have a stock air intake i have a short ram so i just gota pluc the hose ty for
        the help guys
        THEN NOW
          the help guys
          The black box on the fender wall is for your OEM intake box. If you no longer have the intake, you can get rid of it.
            Make sure you cap the vac line if you remove it, mine had bad leak before i caped it.
              yes it was revin high before i caped it but now its normal thnx again for the
              help
              THEN NOW
                help
                no problem
