As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
another question about camber
    ok so as i was driving home from work today in the rain the rear of my car kept getting squirley almost like as if it were a rear wheel drive car and your punching the gas my question is would to much negitive camber cuase this ?
    too much rear camber will make it snappy, i doubt that is your problem though, could be bad bushes, or poor rear alignment, get both those looked at first.
    UKDM 93 CB3 Page (1) H22A U2Q7 LSD
    UKDM 91 4ws Page (3) OEM Minter
    NOW H22A U2Q7 SWAPPED
      i know i need an alignment all around but didnt know it was bad enough to cuase that it was actually kind of scary cuz i wasnt expecting it
        It's quite possible that the insides of your back tires are bald as shit... try taking a look at them. if the insides are bald, and you have a lot of negative camber, then the tires are bald... because that's the part you ride on. Replace the tires.
          Yes. When the tail of your car kicks out as you described, it's usually an indication of lack of grip in the rear. The other alternative would be to possibly flipping the tires, but that's your call, of course, that does depend on how bad the wear is.
          | Cali Accord Meet | FatFourCustoms | HS4Lyfe
          Do It Once, Do It Right!
            If you have directional tires that will rule our flipping them, otherwise it would be a good way to go, if there is some tread left.
            We are "Slow and Reckless Racing", LIKE us on Facebook to keep up with our progress.
            https://www.facebook.com/#!/pages/Sl...03065806427543
              I totaled a 92 DX for that very reason... and it was bone stock. I was just too cheap to replace both front and rear tires, so I kept the "good enough" tires on the rear, and got nice new front tires. Tapped the brakes too late into a turn because I wasn't paying attention, and spun into a wall.
              And directional tires can be flipped, in a way... you just have to unmount the tires and remount them on the opposite wheel.
                If you believe the signs at walmart tire, you always have your new tires in the back to prevent oversteer.
                  Yeah... learned that the hard way.
                  The best thing to do is always have 4 new tires... rotated regularly to keep the wear even on all 4 corners.
