help again!!!cold start problems...
    problem:::f22a4 on occasion will start up and idle rough and then almost die after about 10 - 15 seconds car will run fine So far i have changed plugs, cleaned IACV also have new NGK wires gonna clean EGR next....this is pissing me off!!!! car runs great after a few seconds....This cannot be the first time anybody has had this happen.....thanks,,,,,Matt
    Did you check for vacuum leaks?
    1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
    Originally posted by keepinitclean
    I give it 2 weeks before you sell it.
      - Test fuel pressure
      - Test spark strength
      - Test ignition coil
      - Fuel pump priming enough?
      - How's the fuel filter?
      - Check engine on?
      - Tailpipe smoke? Blue , white or black?
      - Compression test
      - Coolant system pressure test
      - Ground connections tight and clean of oil?
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        This happened to my friends Celica, and it turned out to be his distributor. Have you checked that?
