So I have an f22b that I want to replace the timing belt I was reading about timing belt kits for it and there is none so can anyone tell me what parts do I need and out of which engine should I use thank you
jdm f22b timing belt
I'm pretty sure that engine uses the same belt as the f20a dohc.
The belt you need is from a 1988 dodge caravan 2.5 liter
The belt is identical in every respect to the belt that comes off of the motor
The diameter, teeth count and width are all identical.
I carefully inspected the belt to the OEM honda pt2 belt before i installed it.
Originally posted by Accrdwgnguy View PostTensioners, water pump, and balance belt are stock F22A Accord parts.
The water pump is actually unique to that motor. The gear on the f22a/h23a one is different.
