hey in new to hondas iv done lots of research but i have some ?s i just got a 91 cb7 coupe its been swapped it has a f23a1 vtech but yesterday it started using oil but it wasn smoking or leaking and when i was cleaning my air cleaner and it was full of oil idk y and vtech dosent always hit and when it dose it hits late (5200) i know what vtech is
oil in air cleaner
Originally posted by mattman38960612 View Posthey in new to hondas iv done lots of research but i have some ?s i just got a 91 cb7 coupe its been swapped it has a f23a1 vtech but yesterday it started using oil but it wasn smoking or leaking and when i was cleaning my air cleaner and it was full of oil idk y and vtech dosent always hit and when it dose it hits late (5200) i know what vtech is
Is it a stock air "cleaner" or an aftermarket cone "cleaner". Is it a short ram intake "cleaner", or a cold air intake "cleaner" We need to know this info about your "cleaner" so we can have an idea of what we are working with. And yeah, its VTEC, not VTECH. But you already know that, says so right up there.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Well oil will get into the CAI near the throttle body because of the hose that connects to the valve cover. Now if its an excessive amount that could point to a problem. SOME oil is fairly normal, but a lot isnt.Originally posted by mattman38960612 View Postits a cold air intake, theirs no exhaust on it but iv had 4 other cars that had no exhaust it didnt hurt them could that be y (vtec) is hittin so late or could that cause the oil in my intake some one said a back fire could cause itOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
So its leaking from the filter itself? That COULD suggest rings, unless its red oil then that means someone over oiled the filter. If its black, that could indicate your rings are bad and allowing excessive blow by and shooting oil thru the VC port.Originally posted by mattman38960612 View Posttheirs alot its leaking through my filter what kind of problem would that indicate
my friend thinks its bad rings but this motor only has 60k well thats what i was told any wayOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Give it a shot, might work.Originally posted by mattman38960612 View Postits black im going to try changing the oil and useing some engine restore i used it in my saturn worked awesom for the valve seats in that and maybe it will work for the rings if not ill just put an h22 in it
