jdm f22b timing belt
    Back trying to get answers on parts needed and out of which usdm cars compatible with my jdm f22b mostly water pump which one will do it and the timing belt how many teeth it has cuz 88 caravan its a chain and the 89 has 124 teeth can someone help please
    newer gsr belt..u need a belt with 126 teeth and its real tight to put on but it goes.
    my new turbo build
      Have u done it or u have read about it??
        I saw u have the same motor boosted does it runs good?? And Wat water pump should I use in my timing belt situation
          Go to rock auto and look up a 1988 DODGE GRAND CARAVAN SE 2.5 liter
          The belt is 126 teeth and an identical match to the belt you pulled off
          this is the belt i am using on my f20a dohc which uses the same belt as the f22b dohc.
          I'm not so sure about that. I would stick with the carvan belt
          it was identical in every regard to the PT2 belt.
            I went to advance auto parts and it shows that all caravans in 88 use chain
              Tell tell them they're wrong
              You can look it up on rockauto.com right now if you don't believe me.
              You need to specify the 2.5 liter motor.
