HELP!!!!! my cb7 is backfiring??????
    So this problem just started yesterday and today I. Replaced my spark plugs and replaced the ignition coil & its still backfiring it sounds like it wants to turn off but farts instead until I. Step on d gas????? Any suggestions???????????
    do you have any CEL's? And are you sure you have the right firing order?
      Have you recently adjusted or replaced your distributor? If so, did you set your ignition timing properly? Have you replaced your timing belt recently? If so, are you sure the cam gear isn't off by a tooth?
      Backfires occur when the air/fuel mixture ignites either in the exhaust manifold, or as it's exiting the exhaust valves.
        sounds like firing order to me
