I'm planing on cleaning my IAC valve. I need to know whether or not there's a gasket under there that will need replacing. Thanks in advance.
Gasket needed for IAC vavle removal/re-install?
Originally posted by organ View PostI'm planing on cleaning my IAC valve. I need to know whether or not there's a gasket under there that will need replacing. Thanks in advance.
its always wise to get a new one.for sure,your iac valve gasket is has harden and ready to snap once you remove them.
Originally posted by stunin92_accord View Postits always wise to get a new one.for sure,your iac valve gasket is has harden and ready to snap once you remove them.
These aren't like other rubber gaskets inside the engine. They never touch oil which slowly absorbs in and petrifies the rubber making it hard and in some even brittle.
yes your right,they never touch oil.but,the heat from the intake manifold,coolant flowing through the IAC valve,and the amount of torque on the bolts squeezing that rubber.plus when was the last time that the previous owners had change those rubbers?
Originally posted by stunin92_accord View Postyes your right,they never touch oil.but,the heat from the intake manifold,coolant flowing through the IAC valve,and the amount of torque on the bolts squeezing that rubber.plus when was the last time that the previous owners had change those rubbers?
