Replacing turn signal(blinker) bulbs
    Hey,
    I have a 91 Accord Ex and the front blinker bulbs are going out. I bought new ones to replace them but I cant figure out how to replace them because i cant do it through the hood or under the bumper. I have to take the lights out dont I? if so how do I do so without breaking the lights?
    Thanks,
    Antonio
    theres 1 screw on the ends of each light. you have to go through the inside top corner of the bumper to find them. then just turn it and it should come out.
    COUPE K24
      Next to the headlights or in the bumper?
      Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
      93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
        Its the Corner Lights or Bumper Light ?
        Each other have one screw, its pretty easy, 5min job and its done..
          true 5 min job for the bumper light the screws are at the end of each light all you have to do is push phillips in and unscrew them if its the corner lights the screws are located at the top by the edge of the fender unscrew them and gently release the assembly from the clmps that hold it becaue you dont want to crack or break the assembly depending on how old hey are.
