vehicle speed sensor?
    Can anyone help with replacing the speed sensor? There seems to be some kind of hose or line that's in the way? Do I have to remove that in order to get to both of the bolts that bolts it down?
    yes you need to remove those hoses. be careful pulling them loose as they are full of power steering fluid.
    COUPE K24
      Is there any way to work around it? I dnt wanna mess up my power steering. Also I noticed at the end of one of the lines there's a pin that holds a ball looking thing in place. Is. That where I should remove. It from?
        nah because those hoses are made into the sensor. those hoses are what controls how much input the power steering offers based on your speed.
        not sure on the other question.
        COUPE K24
          Ok thanks for the info. Ill be trying this either today or tomorow afternoon.
            shouldnt take too long. i swapped my vss when i did my trans swap and it took ~5 mins.
            COUPE K24
