front suspension question.
    Okay so i just replaced my rear shocks. I'm saving up to do the fronts. i know with have struts up front. I have max speed coilovers (Ebay i believe) And i was wondering if anyone knows if i have to have the special tool to do the struts with these coilovers? (tool to squeeze spring). Thank you. I believe when you buy the shock it comes with the strut to right?
    MRT>http://www.cb7tuner.com/vbb/showthre...70#post3021770
    first thing:
    We use struts, so yes when you order your front struts that is what you get.
    To answer your question you will need to rent a spring compressor from your local auto parts store to get the top hat off the front shock/spring if you plan to reuse it on your new set up.
    My Members Ride Thread
    You have to think outside the box to get IN the box!
      With those shit coilover sleeves, you will not need a spring compressor. The spring will be flopping around on there the second you remove the shock from the car. I DO, however, strongly recommend you replace those shit coilovers. Especially since I'm quite sure you're not getting shocks that would handle a drop or a high spring rate. Am I correct?
        Right now im just getting Kyb gas filled shocks. Saving up for some real coilovers but Do to me getting 8 hours at work a week i cannot afford anything right now. But thanks, for answering my question!
