Thinking of putting The Ground Control Eibach coilovers with the Koni STR.T's on my wagon. I know the Koni's are quality, but not sure about these coilovers. I want to go lower than just a lowering spring and still maintain somewhat of the ride quality and a little performance. I will admit that I have to stay within a budget on this. Anyone using these or have any other recommendations? Of course I have read the suspension stickies & have about a $700 budget, not including the camber kits. Thanks.
Eibach w/STR.T's
For your budget, if you want to go lower than regular springs would take you (not a great idea, IMO... but it's your car...) then I would suggest getting a full coilover kit. F&F Type 1 would fit in your budget, I believe, and they would do what you want.
The Koni STR.T are very good shocks, but depending on the spring rate and height that you want, they may not hold. The best thing to do is to call Ground Control and ask them. They offer a range of spring rates for their sleeves, so perhaps they could offer you one that would work with the STR.T. You'll need to know how low you want to go, though.
These F&F Type 1's are exactly what I am looking for. At that price I was'nt sure about the quality though. These are what I will get as I really did'nt want to put coilovers on my car. I had a bad experience with some cheap coilovers on a EF Civic hatchback once. Rode like a tank-literally. Very happy with this find & if you guy's are saying they are worth a crap, I'll try them. Thank's again!
I'm on F&F Type I's, and have been for about 6 or 7 months now.
I brought them as a temporary solution as I needed shocks bad, so I used them as a solution to my problem. I was supposed to upgrade, but I'm kinda being responsible as I'm not trying to spend major money (house saving). Some things have been put on the back burner.
Anyway, they are okay. Once in a while in a city full of pot holes, they can be harsh and irritating. For the most part on an everyday basis, they provide an okay ride comfort, good handling, and seem durable. I'm about 2-2.5" dropped, and I don't really have too many complaints.
Overall, comparing to stock components, they rate good just not as comfortable, but handling is greatly improved.
8 out 10 from me.The Lord watches over me!
- D. Chappelle
Ground Control sleeves are absolutely good quality. They're the only sleeve I'd ever consider myself (though I would probably never get such a thing.) Full-bodied coilovers aren't much different... they're the same as the sleeves, only instead of the threaded part slipping over the shock, it's simply a part of the shock (good for ease of installation and ensuring that you have a matched spring/shock... not so good when you blow the shock and have to replace the entire unit!)
Keep in mind that the threaded parts need to be maintained, or they can seize. It's probably less of a problem for you in NM than it is for me in NJ.
I much prefer a good spring/shock combo myself, but that's just me.
As for F&F's quality... people have nothing but good to say about them, and they actually took the time to develop a CB specific setup, not just a "90-97" setup like most manufacturers... so I can appreciate that. (stickydiljoe of "the chronicles" is partially to thank for that.) I don't know where their coilovers are made, though, and by what process... so I can't say for sure that they're better than some of the cheap crap on the market. All I have to go on is their reputation, and as I said, I've heard nothing but good things.
Actually, Ground Controls paired with Koni Yellows will perform as well as (or better than) most full coilovers on the market for our car. Also, they offer a variety of spring rates, so "ride good" depends on what you get, what you need, and how you define "good". You can get Ground Controls that are so stiff they'd only be useful for a racetrack.
In the future, if you don't have anything useful to add to the conversation other than subtly repeating what others have already said (only leaving out all the substance, and infusing it with your own uneducated opinion), just don't bother posting.
Yeah, those Bilstein's are nice & they would probably go good with the Ground Control's. Now I am torn between the two choices. F&F 1's or this setup- I will have to make some phone calls tomorrow. Oh, these Bilstein shocks have a really good price at Nopi too. It would be a little over my budget but might be worth it for ride quality and drop that I am going for.
Also, you may want to have an extra $100-$150 set aside for miscellaneous issues that may arise. Bushings, rusted/uncooperative bolts, a bearing or two, alignment. This is just an heads up. Sometimes when you fix one part on an almost 20 year old car, other thing began to fail.The Lord watches over me!
- D. Chappelle
VERY true. I just put new springs on my car on a whim... my friend wanted my H&R Race springs, and I wanted to raise the car a bit, so he got me some Neuspeed Sport springs. The bolt through bottom bushing on my driver's side rear decided to seize, and the bushing shredded. $30 part, and if I can't install it myself (it's not an easy one), it could be even more to have it professionally installed. Technically, I should be replacing both sides while I'm at it.
