h22 swap w/ auto to 5 speed
    Ok guys I have a problem... After I did the h22 SWAP I also did the auto five speed and now the fuel pump isn't priming. Does any1 have an idea what it could be
    You've done so much custom work that it's nearly impossible to even guess at what the problem may be with the information you gave us.
    Generally, the fuel pump not priming would point to the main relay as the most likely culprit... but with everything you've had to mess with to do your conversions... it could be damn near anything.
      check the thermostat ground.
      COUPE K24
        Seems common sense, but check the power and ground to the pump.
        A lot of times, stuff like this happens because you simply forgot to plug something in.
          sorry for not giving more information but we got it to start today
          thanks for the help guys
            What ended up being your problem?
            92 CB7 F22 5 speed.
            ^MY RIDE THREAD^
              Yeah, you gotta tell us what the root cause was!
                the main relay was fried took another one from my friends old cb7 and bomb start up lol
