Ok so this is how everthing start it, I burn my 2nd Gear on 5 speed m2b4 transmission with lsd and i decide to get a regular transmission from a prelude, none lsd couldn't affort m2b4 tranny, way to pricy.. Any ways, me an my friend did the transmission swap, so he did top part i did bottem before all this my car was really powerfull dyno was 210hp 179 torque, no check engine light and v-tec kicks in at 4000 rpms.. Anyways we finish the swap ..car didnt want to start at the bigenning so i found the problem, one of the wires was ripped from I think it was the CTS sensor, so i fixed it car now sounds good but i decide it to take it for a run to test my new transmission, i notice that went i try to speed up and rev to high RMPS, I stomp on the Gas pedal as soonest it hits 5000 rpms IT STOPS like it would be red line!!! So i went back home i notice that there is something wrong with it, there is a red wire coming from the harness above the distrubitor that is disconected like ripped off and a vacuum house from the vacuum control box disconected.. I belive its the 2nd one from the right,not the one that goes to the evap can... well i couldnt found the problem, another problem that i found it was the temperature gauge is not working :-( ... Today i was driving it like that and my speedometer stop working also so its really bad and gave headaches... I spend so much time already working on it and i cant figure out i done research an no luck, one other of the things that he mess up its he conected the baterry Terminals the wrong way so he burn my battery fuse so i replace it....we did all this from 5pm to 2am....any one have any ideas what can it be wrong with it or this problem has it happen to any one alse please any IDEAS THank you every one!!
92 cb7 with jdm h22 wont REV pass 5000PMS any ideas!!
You don't take out the fuse marked ECU. You take out the fuse marked Radio/Backup. Or just disconnect the battery cables. You don't need to do it overnight. A few minutes is all it takes.
If you have a chipped P28, I STRONGLY recommend you get an unmodified P13 for troubleshooting purposes. Without knowing what was done to your ECU (I hope it was properly tuned for your motor...) it's hard to say what's wrong, and something clearly is.
Also, what IS done to your motor? because a stock H22A should only be putting down 165-170whp.
Please use punctuation when typing. It's damn near impossible to figure out what the hell you're saying. If you want us to spend our time helping you, spend a little time making your post understandable.
ok so the Fan swith A on the thermo housing its behind the one in the back on the back were the long house goes-fun works fine i unplug it and it goes off..
my other question does the sending unit wire is located on the block and any idea whats the color of the wire
fan switch B is it in front of the car by the fan
