2 easy questions. (93 Accord EX)
    Well, the first one is squealing on start up. I know this is a common problem with older cars, and probably a common question I could have searched for and found the answer, but it seems to be a little more complicated then that. It only happens if it's cold, and only for about 2-3 seconds. I checked my belts for slack, didn't see anything over half an inch.. I sprayed my alt belt with wd40 and the squealing seemed to have stopped for about a day or so. So that's problem one.
    Second problem, or question is.. When I make a turn at a fast speed, I hear what sounds like ... tire screeching? but it is much softer than the usual "ERRRRTT" sound. Not sure if it's just because my tires are low on tread, or something else.
    You kinda answered your own questions, 1. you might just need a new belt or try to tighten them. Even if it seems tight enough you might still have to tighten. 2. bald tires can squeel at the slightest turn.
    BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
    BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
    Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
    CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
      Just a little advice. Don't spray stuff esp. Wd40 on your belts. You probably need to replace your belts.
      http://www.cb7tuner.com/vbb/showthread.php?t=178069
        I've been told never spray anything on a serpentine belt.. not even belt dressing.
        '94 CD5 EX F22B1 Automatic
          one thing.. dont use wd40 lol i would have done the same till i was stopped, wax if anything at all. it may just need to be adjusted also. its embarrasing at night i must say wakes the whole street up! and that little noise could be your axle! just from my experience anywayss
