window help
    window help
    trying to figure out what to with this window. just dont wanta go to a repair shop and they try to get over and tell me some BS. looks like something popped off or was taken off. just wanted info. thanks
    I can't really tell from the picture but it looks like that button is missing. Go to a junkyard and find a coupe to get it from. I hate messing things up in the junkyard but I don't know of any other way to remove this button other than breaking the window. They usually get so stuck on there after so many years that removing them by unthreading them is impossible. Break the driver's window and then look at the channel the button travels in. You'll see a black strip that you can remove. Once it's removed you'll see 4 Philips screw heads. Remove all of those and then the channel can be removed. Grab the button and it will be attached to the other piece that slides in the rail. Take it home and soak it in penetrating fluid to get them apart. It should be self-explanatory to reinstall it. Just don't break your own window! You may want to put a dab of RTV silicone on the underside of the button so that it's not coming into direct contact with the glass once it's reinstalled.
    If you decide that's too much work the dealer can order you the whole thing with a new rubber seal for $19.
      sorry bout the pic but from what im reading it sounds like you know what im talking about. just hate havin that window off track each time i roll it down. THANKS
        mine was like that for 2 years. i got one last summer and finally fixed. no more rattles, leaks, or noises.
        i HAD to break the window to get it out. threw a tq converter through it. haha
        COUPE K24
          so basicly i just gotta finda a coupe at the junk yard break the window and take the lil button and slide it onto mine without breakin the window
            so i was finally able to find a coupe that didnt have the same problem i did.. i was able to get the pin but now i cant seem to figure out how to take it apart without messing it up...
            have this
            need it to do this
              there is a lil flat head in the middle, take it out with out braking the circle part n there you go.
              paypal info:leonardorivera50@yahoo.com
                thanks i ended up goin to the junk yard and ended up finding one that i was able to unscrew. good lookin tho
                  It could be like mine. Rolls down fine but on he way up it clicks grinds and wobbles. I have to up stop and line it up and then roll up again. The regulator and motor have been replaced 3 times. It'll work fine then mess up gin. Dunno what to do.
                  IridiumCore
                  HCK-The Beginning
                  Your drunk she doesn't look that good.
