Help with the temperature gauge??Picture inside!!
    Ok I did some research on temperature gauge an i keep finding that it goes under the dizzy the only sensor that has a single wire plug but i found a picture of my engine, this was before i swap my transmission and the wire i belive it got lost so now im trying to figure out if it goes to conected from the upper radiador house sensor to the red wire from sending unit http://www.facebook.com/photo.php?fb...type=3&theater
    Okay two things, you're a bit unclear with what you're saying, and the pic isn't working. If your gauge isn't working then look for the sensor. It is basically right under the dizzy like you said. Yes, it is a one wire connection. The wire should be red. If im understanding you right, then i had a similar problem. It turns out the sending unit wire was cut and not making a good connection. If your gauge isn't working then check the wire and then the sensor. It's a little tiny and like i said it's basically under the dizzy. The one right next to the ecu temp sensor. Good luck.
      My whips so clean I can see the reflection of your car in the reflection of my car on the reflection of your car
