This is my third cb7. I owned two previously and did not encounter what i have seen today. Since i bought this cb7, the washer pump never worked. I checked fuse and it was good. The wipers run off the same fuse and they work, which doesnt make sense to me as to why the pump would not. So i assumed the pump was dead. I bought a new pump and when i went ro replace it today, i notice the original clip/harness for the pump was only grounded. Someone had flipped it because they were not using the positive from that clip. There was an additional wire which i traced that ran through the firewall under the dash and found it not connected to nothing. I tried the original clip on the new pump and no luck. So i set it up the same way they had done it but connected the wire they had run to a 12v toggle switch, sure enough the new pump is working. I would like to reconnect it and have it set up so i can just pull the stick on the wheel and have it spray like i should. It got dark outside and cold. No time to follow the wire. Does anyone know from past experiences were the wires for the pump come from so i can trace it back. I did take a quick glimpse but was not able to follow it. Any help is great, thanks.
washer fluid pump
washer fluid pump
Last edited by trinistylez; 01-22-2012, 11:22 PM.Everyday is one day closer to completing my cb7 <3Tags: None
try removing the steering column covers and you should get a better view of the wiper stalk and the corresponding wires. You might have to remove the steering wheel to actually unplug them.
good idea. Ill look for post regarding how to remove the steering wheel because i have no clue. Beforr i go that far bavk though, im pretty sure the wire from the original clip has just been cut, cause its still grounding. if someone knows off hand where to find it that would be great before i go digging in the steering column.Originally posted by Losiracer2 View Posttry removing the steering column covers and you should get a better view of the wiper stalk and the corresponding wires. You might have to remove the steering wheel to actually unplug them.Everyday is one day closer to completing my cb7 <3
