Gas level sensor removal
    I took the metal cover off but I can't figure out what you do next. How do I remove it? I tried hammering the notches with a flathead thinking it rotates but it's not budging.
    it rotates try the other side
      Take a shop vac to it first and get all that dirt out of there if not it will all fall into the take once you get it open. Also that dirt is probily not helping your case when trying to spin that collar
      92 CB7 F22 5 speed.
      ^MY RIDE THREAD^
        I got it thanks. I beat you to it, vacuumed all the crap up. I just needed to use a larger flathead and a bigger hammer and really hit it hard. Checked the ohm readings on the sensor and everything's in-spec, so I wonder why my gas gauge is so inaccurate. The connections had some gunk so I tried cleaning that. I guess I'll see what happens next. Might write a tutorial though.
