performance topic
    performance topic
    The F22A blocks are all identical. The F22A head castings are all identical. The only parts that are different between the F22A1, F22A4, and F22A6 are bolt-on parts (the F22A6's intake manifold and camshaft being the most signifcant upgrades, along with the ECU that is programmed to use those things)
    The SOHC VTEC F engines are actually a considerable downgrade if you're looking for a platform to modify for performance. The valve angle and port design is inferior to the F22A.
    If you have an F22A1, and you want to make some real power with it... here's my suggestion:
    Get a Bisimoto header. $630, and a lengthy waiting period... but the gains from that single part alone will be greater than a SOHC VTEC swap.
    Get a Bisimoto camshaft. Stage 1 or 2 would be wise. 2 requires some valvetrain upgrades.
    Get some headwork done to your F22A head (or, probably better... get a spare head, they're cheap, and have that worked)
    Get an H23 intake manifold and throttle body.
    Upgrading the bottom end would be smart, but if you want to go the cheap route, at least replace your rod bolts with ARP bolts. It will rev more safely with those.
    A 3" short ram intake with a quality air filter (AEM or K&N), and a 2.5" exhaust would also be very smart.
    Finally, once all that is on... a P06 ECU, tuned on a dyno...
    That setup would very likely get you near, possibly over, 200whp if your bottom end is healthy.
    so if you put higher compression pistons in you will get over 200 hp?? i know what im doing
