switched from an a6 to an a1 not getting any fire from the distributor and when i turn the turn signals on the safety switch from the brake pedal to the shifter clicks with the signals anyone have an idea?
need help f22a6 to a1
So it's turning over, and getting fuel? But no spark?Originally posted by f22a6accord View Postswitched from an a6 to an a1 not getting any fire from the distributor and when i turn the turn signals on the safety switch from the brake pedal to the shifter clicks with the signals anyone have an idea?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I don't think so, but the OP probably either converted internal to external dizzy, or could have left the ECU ground of the t-stat housing.Originally posted by Leung View Posthave you checked all your grounds? I think the one underneath the distributor is the one that people generally forget to hook back up.
maybe someone else can answer this but didn't the later versions of the A1 have an external igniter?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Its VERY common to forget it.Originally posted by f22a6accord View Postall the wires matched up except the iab and im not worried about the 15 horsepower difference but i might have overlooked that groundOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
found the ground that i forgot to bolt cant believe i forgot it because i had to take the old one off the new motor when they cut every wire power steering and all went great still a little concerned about the fuel problem put 10 in the tank a little over 1/4 tank from the light being on drove 9 miles to see how it drove gas went way down quick too quick know a reason for that? also my tach is kinda jumpy if you get what im saying sometimes it will say its not idling at all or at like 100 rpm motor doesn't bog down or anything shifts great though theres a hissing noise also some where haven't really looked for that but i think its the a/c pulling air through the condenser i disconnected the a/c lines planning to get a shorter belt so i can get rid of the dead weight
Sounds like a bad ignitor.Originally posted by f22a6accord View Postfound the ground that i forgot to bolt cant believe i forgot it because i had to take the old one off the new motor when they cut every wire power steering and all went great still a little concerned about the fuel problem put 10 in the tank a little over 1/4 tank from the light being on drove 9 miles to see how it drove gas went way down quick too quick know a reason for that? also my tach is kinda jumpy if you get what im saying sometimes it will say its not idling at all or at like 100 rpm motor doesn't bog down or anything shifts great though theres a hissing noise also some where haven't really looked for that but i think its the a/c pulling air through the condenser i disconnected the a/c lines planning to get a shorter belt so i can get rid of the dead weightOriginally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
