Overheating
    Overheating
    I've been searching a little while and still don't understand why my car keeps overheating. I was driving it and the temp went all the way to H and when I opened the hood just white steam. No leaking just steam, I popped the cap to put water in and more steam spewed out with extremely hot water. Anybody know why? :Confused: Thanks in advance
    My Baby "CLEO", Slowly Making Her Mine
    Could be your thermostat or head gasket. I had a 91 CB that had the same problem but mine was both the thermostat and headgasket.
      Does your car sputter and/or loses power sometimes?
      Does your car sputter on start-up? Especially cold?
      How old is your water pump?
      Is there enough coolant on the reservoir and radiator?
      Does the temp go down when car is in motion?
      Did you try re-bleeding the cooling system?
      Check your spark plugs if they're white and have powdery residue
      Check your spark plugs if they're wet
      Get a cooling system pressure check.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        yeah this one is a 91
        I'll just have to get a check because I just bought it Monday. I figured it was the water pump didn't know it could be a number of things. Thanks
          Hopefully u didn't blow the head gasket going all the way in the H like that
            Do not put water in your radiator/sooling system, you will eventually crack/damage your motor. You are boiling your engine.
