Code 9
    Code 9
    This is preteining to a friends car
    Its a 1993 EX sedan
    It was giving code 9 for the CYP - cylinder sensor
    We went over to the junkyard and grabbed another distributor but we still have the code
    What should i look into next?
    Well it is the JY so anything u grab out of there is hit and miss. The chances of picking up a dizzy with the same issue is slim but not impossible. Is there a way u can use another distributor (other than the 2 u already have) just to double check if thats the issue?
      Just curious, wat happens when u have a code 9? Does it not want 2 start or something
        Reset the ecu and see if the code comes back
        My whips so clean I can see the reflection of your car in the reflection of my car on the reflection of your car
          Having a lose connection on the injectors will trip the CYP cell aswell since it all works off one another.
          02 Crv
            I'm not really quite sure. The engine doesn't seem as powerful as mine but it still moves well. It might be the CEL or it might be the fact that his car is more worn and tired than mine.
            Already did that, it came back right away.
            If an injector connector was loose i would imagine the engine would run a lot worse than it does. For the most part it runs pretty good.
              The CYP will cause the car to act up like it's running out of fuel, but the problem will be random it will not be a steady issue until it is completely gone.I've had the issue on my old ED6 and my CB with my civic it was wiring or the distributor, but on the accord it was a lose connector on cyl 2.
              Just giving you ideas....... other than wiring/distributor/or connection issues i don't know what else it could be.Maybe a faulty ecu but i highly recommend that everything else is checked first.Since its your buddys why not try out your distributor on his?
              02 Crv
