What PSI does the OIL LIGHT come on
    At what PSI does the oil light come on in our cars. My guage has been reading anywhere from 8-10 at idle. I know the manual says 10 PSI as a minimum. But I've always thought it was 10 PSI for every 1000 RPMS and if my car idles at 750 RPMS then I would expect 7.5 PSI is that correct.
    At what PSI does the oil light come on?
    1991 Honda Accord 2DR LX 180,000 Miles RIP
    When I was looking for oil pressure switch for my motorcycle, I found there are two pressure settings for generic switches, 2-4 and 3.5-7.5 psi for possibly different applications. There could be more different settings.
    I have no knowledge for Accords. But it would be similar numbers, I'd say.
    A&P-IA
      I dont think the oil light comes on with low psi. I have seen one that drove around without the oil cap and there was no light on. But it could have been a fluke that there was no light.
      "Good judgement comes from experience,
      alot of that comes from bad judgment"
        Having the cap off has no influence on pressures.
        I believe under 5psi.
        wat?
          So my thinking about 10 psi for every 1000 rpms is about right. With me running 8-9 psi won't damage any parts?
            No one can guarantee you that over the internet.I thought a cold start PSI was suppose to be higher than that, but i don't remember for sure.
            02 Crv
              my cold start psi is around 85 but when it gets to opperating temp it drops to 8-10 at idle.
              When the rpms drop to 1000 when it is warming up the psi is around 25
