Random thermo fan problem/ over heating issue and other issues
    Hi everyone,
    Randomly driving yesterday in heavy traffic all of a sudden the temperature climbs up(didn't over heat thank-god) and i pull over and my father realises only 1 thermo fan was running with or without a/c on. Now today they seem to be both working... is their any test or thing i could do to see what's going on :P or is 1 only meant to be on without a/c, also has new waterpump and thermostat a few months or so ago.
    On a side note i have done everything you guys said to but my hand brake light and bulb out light is always on and even after installing my new spoiler all my lights work how ever it doesn't make sense to me why its on could it be a short?
    Thanks
    Anthony
    The temperature rising is a pretty common issue, Mine used to do that, I ended up just wiring the Fans to come on with the ignition. The first place I would start is the thermostat though.
    Your e-Brake light being on could be just the switch on the actual e-brake, try taking the center console out and see if its in place.
    The Brake lamp out light its usually the "solders" (Don't know if that's a word) on the black boxes on the taillights that go bad since moisture gets into them and rusts them, try re-soldering them or grabbing other ones at the junk yard.
    Hope that helps.
    1993 Accord EX
    2011 Subaru STi
      Hope that helps.
      The thermostat was good today so i guess its functional... If only it could talk as it has to be reliable :/
      My ebrake and bulb out light seem to be on same circuit when something is wrong with my brake lights.
        Have you checked your brake fluid, I think I read somewhere that can also cause those lights to come on.
        1993 Accord EX
        2011 Subaru STi
          Nah its full i checked that first ^.^
            Ok guys i know this is an old thread but...
            Could my coolant temperature sensor be causing only 1 fan to come on or is it unrelated?
