cruise
    cruise
    This is a separate problem from my other fuel related problems so wasn't sure if I should start a new thread or not.
    My cruise works , sometimes.....
    It has a pattern , a perfect pattern. When the car is cold , it never works , cruise light comes on , buttons do nothing.
    But , after maybe a 45min drive it will randomly start working , and work perfectly after that. After it starts working it will work 100%. Until I turn the car off for the day , and by the next morning I'm back to square one.
    This is a 92 and it's auto. I saw fixes for manuals but didn't see much about the autos.
    Almost everyone on here HAD cruise control at one point
    Do you know how to adjust a throttle cable? If so great.
    basically all you need to do is go up to the cruise control actuator on front left corner of the car ( the little round dish looking thing with a throttle cable going to it behind the headlight ) and adjust the cable so it doesn't have a huge amount of slack in it.
    Thats what i would try first at least.
      how do I know if there is slack in the line the cable is covered
        Loosen the adjustment an just feel it
        Pull the cable as far out as you can until you feel it start to pull the actuator, back off a tiny bit and tighten it up there.
          pull toward the front or back of the car? Like , away from the dish thing or toward it?
          Also , is that extra belt on the outside of my engine just for the AC? Cuz my ac doesn't work so if I can simply remove it that would be good.
          When I move the adjustment back and forth , it only moves the cable cover and not the cable.
