Hey guys this is a great site so far. Yesterday at 9pm I purchased my first car, a green '93 accord. After test driving twice I thought it was worth the money. Only has 140k on it, but there are a few minor problems. When it shifts from 2nd to 3rd it seems to be a little late, and same for higher gears. I'm wondering if this is because of the exhaust leak? Also, both the brake light and the abs lights are on, however they weren't on my first test drive. The breaks only barely squeak and don't slip at all. Not sure why this is? And there is a broken cv on the passengers side. I'm a total car newbie as this is my first, so all help and comments are appreciated. Thanks guys!
Exhaust leak, abs light, brake light.
get the cv and brakes done asap... defiantly the cv...Originally posted by Jwright94 View PostHey guys this is a great site so far. Yesterday at 9pm I purchased my first car, a green '93 accord. After test driving twice I thought it was worth the money. Only has 140k on it, but there are a few minor problems. When it shifts from 2nd to 3rd it seems to be a little late, and same for higher gears. I'm wondering if this is because of the exhaust leak? Also, both the brake light and the abs lights are on, however they weren't on my first test drive. The breaks only barely squeak and don't slip at all. Not sure why this is? And there is a broken cv on the passengers side. I'm a total car newbie as this is my first, so all help and comments are appreciated. Thanks guys!
http://www.youtube.com/watch?v=5xIUAMl-oRQ
that will help you on the front brakes, and while your doing that its easier to do the cv
How much did you paid for the car? Unless you can do it yourself, it's going to cost a little to get it in top shape. I got my 90 LX 4AT about 4 years ago for $2150 which is a little high but the only problem was distributor o ring and valve cover. Every thing else was done. The previous owner, had the car maintained mostly by Honda certified shops. It only had 136K miles. First thing I did was replaced the tires and did an alignment. It was so out of alignment that all tires was showing metal on the inside half of the tires while the outer part were all brand new.
I have been working on it ever since. It's all stock. Now I just need to figure out how to get it to give better gas mileage. It's at 22 and I know it could be better. I did NGK plugs and cables, caps and rotor. Timing is on. Not sure what else. I did valve adjustments and clean the EGR ports and valve.
Oh well.
