distributor leaking oil
    i would like to know what to do because my distributor is leaking oil i changed the distibutor cap and rotor but still leaking oil it looks like it leaks from where the distributor connects to the motor
    Call the Honda dealer and order the distributor seal. It's an o-ring that goes around the shaft the connects to the cam inside the head. They all do this. You could have found this out by searching.
      Replace the inner seal and the outer seal on the dizzy
      here is the how to do it
      http://www.cb7tuner.com/vbb/showthre...ht=distributor
      Here is a place that i ordered mine from you need the distributor seal and o ring
      http://www.autopartswarehouse.com/ca...tributors.html
