The plug isn't loose just the wire. But when I put the wire on it does snap, but rides up while going down the road. I never had this problem with my old wires, These were also good until I removes them once.
Acceleration Engine Shudder
So it has happeded again. The number 2 plug wire snaps, but after the engine gets to opperating temp the wire rides back up the tube. I have tried to clean the wire with brake clean, carb clean, and even wd40, and none have worked. After it warms up the oil comes out and starts to make the wire ride up. But I would think that the wire should hold onto the plug am I right?
Would it be a good idea to replace the lower seams around the spark plug tube? I changed the top, but not the bottom.
Can you buy just single plug wires because I just bought these wires a couple months ago.1991 Honda Accord 2DR LX 180,000 Miles RIP
Have you try this?Originally posted by oyajicool View PostHow about swapping position of plugs. Move #2 plug to, say, #1. And see what happens.
If the wire on #2 cylinder still pops off, you have problem with wire. Snapping force is not strong enough, maybe.
If the wire on #1 cylinder pops off, the you have problem with that plug.A&P-IA
Could I try what this guy did?Originally posted by LawlessOneGot it resolved (I think).
Damnest thing, although it takes two or three minutes and considerable exertion to try to take the plug wires off by hand, it seems to be a lot easier to drive down the road and let it pop off itself.
But seriously, I tried making a hole in the top of the boot in the event that it was air pressure building up, and this did nothing.
Finally, took the rubber piece off of the stem that slips over the insulator of the plug and haven't had any trouble since. As a matter of fact, I stopped having trouble with this one popping off, and then a different one popped off, so I took the rubber piece of the end of the plug stem of all of them.
This makes the wires much easier to pull back off, unlike before, but they stay on like this. My only conclusion I can base from this is that the rubber piece is swelling to the point that it pushes the wire back off of the plug enough to either make air pressure blow it off, or the spark jumping between the top of the plug and the connector is making it pop up. It's the only thing I can think off that makes the most sense.
So if your having this problem, do yourself a big favor and take those blasted rubber tips off of the end of the plug wire tubes and plug your wires back on, this may save a lot of aggravation!
I went back to the Bond that I got the plug wires from and told them my problem and without a receipt they just looked on there computer and said yes you bought them. So I gave them my old wires and got a new set Free of charge. All of these are staying in there holes.1991 Honda Accord 2DR LX 180,000 Miles RIP
