I'm new to the CB7 seen but I just got a 92 accord ex and it needs a headgasket car has roughly over 200,000 miles, was wondering how hard is the headgasket job and with that many miles should I be concerned about the piston rings? I want to eventually build a solid F22 engine.
Headgasket
There's no set time for the piston rings to fail. They can go for many thousands more, or they may be done now.
As for the head gasket, "how hard" depends on your mechanical ability. The head has to come off to do a head gasket. If you can do that, then it's not very hard at all. If you're not familiar with taking an engine apart, you may find it to be very hard.
Get a good manual (I suggest one from www.helminc.com) and read. You'll need the manual to do the gasket anyway, so it won't be a waste of money.
x2 What exactly is the car doing?Originally posted by lilg4mdalbc View PostIn addition to what deev said, what makes you think you need a new head gasket?
Before taking advice from here make sure more than a few people give you info in your thread/post. Might be best to answer average than wait for a respose and take off to go do it. Take your time.Originally posted by gh0st View PostHead gasket can be hard if you aren't familiar with that kind of job. Just make sure you research, and listen to the advice given here.
